Need recommondation for new clutch
Old 09-04-2007, 02:45 PM
LSGunZ28's Avatar
Default Need recommondation for new clutch
Well Im going to purchase a new clutch and do the drill mod..
I have a LS7 clutch in now and Aluminum FW
I want a lightweight flywheel, but not as light as the aluminum one i had.
what woul dyou reccomend me?
I have 364 rwhop now, but soon will have 430+RWHP and even after that I plan on exceeding the 500whp mark.
so something that can sustain that kind of power, and in a DD car.
Also the car sees significant track time and dragstrip 6000rpm clutch dumps and has a moser 12 bolt 3.73s.
Im changing my clutch because it was recommeneded by Amer from T-56 rebuilds in connection with some trans issues I was having.
so any input would be appreciated, thanks.
Old 09-04-2007, 02:46 PM
LSGunZ28's Avatar
Textralia or ram is what I was thinking, but is there anything else I should be looking for?
Old 09-04-2007, 02:55 PM
brad8266's Avatar
One of the Tex clutches or a 3+
Old 09-04-2007, 04:46 PM
LSGunZ28's Avatar
why not RAM?
also Ive heard plenty garbage on the spec 3
Old 09-04-2007, 06:43 PM
brad8266's Avatar
Originally Posted by LSGunZ28
why not RAM?
I said the 3+, not the 3. Ive also heard garbage on the tex and the ram, they are all still good clutches IMO.
Old 09-05-2007, 11:25 PM
LSGunZ28's Avatar
Drivability is a concern but not as big of a concewrn as reliability/longevity.
I want the clutch to last over 25,000 miles even i racing conditions, etc as well as a daily driver and spirited driving.
if such a clutch exists and can withstand over 500+ RWHP this is what Im looking for.
Old 09-06-2007, 06:26 AM
brad8266's Avatar
I can tell you from experience that the 3+ holds well for those power levels and drives pretty damn good. What will kill it is excessive slipping of the clutch. During normal driving I take off with mine at around 1500 rpm with minimum slippage.
Old 09-06-2007, 04:01 PM
LSGunZ28's Avatar
Okay. I launch the car at 6k rpm and do this on slicks. I would say 12 - 15 times a month. powershift therough all gears ( when drag racing) and roadrace it for a good 6 hours - 8 hours ( not continuous, with small breaks between) about 3 - 4 times a year.
its also a DD
now after that info. will the spec 3+ hold up well?
and why not a textralia?
I dont really wish to spend lots of money, but if I have to I will (text)
Old 09-06-2007, 09:29 PM
brad8266's Avatar
It will hold up to it, and im sure a tex will as well, and both are good daily drivers. The 3+ is under $550 and is around $800 with a billet flywheel. I dont remember what the tex runs but it is more expensive than the 3+.
I really cant say which one is better because there are too many variables with clutches such as longevitiy and ability to hold power. I will tell you this, both clutchs can hold a lot of power when used and installed properly.
Old 09-07-2007, 01:48 AM
ae13291's Avatar
will u sell ur aluminum flywheel??? pm me if your interested
Old 09-10-2007, 12:21 AM
Vindication's Avatar
Why not a Exedy? Your asking a lot out of a clutch and it seems your looking for value. If this is the case Textrilia is probably a good option.
If your making under 450 rwhp the LS7 is the best one to go with....
Old 09-10-2007, 05:55 PM
LSGunZ28's Avatar
not according to t-56 rebuilds...
which textralia should I go with though?
Old 09-10-2007, 06:50 PM
brad8266's Avatar
the single disk cheaper one from tex should be fine for ya.
Old 09-10-2007, 07:08 PM
text it is then..
my friend wants a rematch when he finishes his car.
Old 09-12-2007, 01:52 AM
LSGunZ28's Avatar
So now I talked to Amber from T56 rebuilds.
she is recommending a SPEC 3 with a shim. because the text and ls7 clutches, when they break in, seem to be not disengaging/engaging properly and thus causing the gear to not go in properly..
I must drive around with my car in 2nd gear for a good 30 - 40 miles and see if my blocker ring is glazed over. if it improves, then Im good. If it doesnt i need a clutch for sure. I should change my clutch anyways, just because Im dumping the car at 6000 rpm on slicks and I know the LS7 clutch doesnt like that.
lastly, I may need to disassemble my trans if it hasnt improved anyways and change my 2nd gear blocker ring. if all feels the same and/or check what else may be wrong.
which if it comes to that, really sucks, since I rebuilt it april 2007.
Old 09-14-2007, 02:13 AM
LSGunZ28's Avatar
Spec 3+ and spec 3 whats the difference?
Old 09-14-2007, 04:45 AM
silverZ98's Avatar
pricy but i say go cartek
Old 09-15-2007, 08:30 AM
ls1leadfoot's Avatar
Have The Ram........too Much Chatter And As Well And A At Leasr A 90lb Pedal.....would Be Great For A Track Only Car Or Weekend Drvr.......do Something More Forgiving.....also Lurchs Really Bad If Your Below 1,800rpm
Quick Reply: Need recommondation for new clutch
