Is this the tool i need to pull the pilot bearing?
Old 09-16-2007, 08:00 PM
noxiouSS's Avatar
Default Is this the tool i need to pull the pilot bearing?
From autozone
http://www.autozone.com/in_our_store...tch/clutch.htm
Old 09-16-2007, 08:12 PM
brad8266's Avatar
thatll work
Old 09-16-2007, 08:15 PM
noxiouSS's Avatar
this will sound stupid but how does it go back on? Just push the new pilot bearing on?
Old 09-16-2007, 08:18 PM
brad8266's Avatar
i tapped it in with a hammer and piece of wood.
Old 09-16-2007, 09:17 PM
kingcuda70's Avatar
use a socket the same size, taper side out. blind hole puller is better/eziear tool..
Old 09-16-2007, 10:43 PM
scgt1's Avatar
you need to rent a slide hammer along with that tool just finished doing the clutch on my t56 in my 91 camaro an hour ago. Now I have to find the post about bleeding the hydrolics on a LT1 T56. Its real notchy shifting and takes a bit of effort. Does get a little better if I pump the clutch though. I had to replace my clutch because the flange on the throwout bearing was ripped off from the fork. Go figure. It bent the heck out of it too. Along with the idiots who I bought the car from two years ago Most of the trans bolts were taken off by hand only a few on top were actually tight.
Old 09-20-2007, 12:47 AM
KCRickSS's Avatar
Check out this thread...
https://ls1tech.com/forums/manual-transmission/524389-ls7-clutch-installed-weekend.html
I used the Autozone blind hole puller...OEM 27128 and it worked GREAT. Pics are in post 7 of the thread - here's a direct link for you with that info:
https://ls1tech.com/forums/showpost....89&postcount=7
For what its worth, the LS7 clutch is holding up fine over a year later but my hydraulics are going out...replacing the master this weekend and hoping its not my slave leaking.
Good luck!
Old 09-20-2007, 01:43 AM
Ferocity02's Avatar
When I went to autozone, they had two different pilot bearing puller sizes, ask them to pull a pilot bearing from their stock to make sure they puller you get will work before you leave the store.
Old 09-21-2007, 07:37 PM
renxwar's Avatar
Blind hole puller +1! I snapped the first removal tool, it took 5 minutes tops with the blind hole puller.
Quick Reply: Is this the tool i need to pull the pilot bearing?
