Clutch Return Spring - How to install?
Old 09-19-2007, 02:09 AM
Ruhrpott's Avatar
Default Clutch Return Spring - How to install?
Ok guys- here's my problem, my Clutch return spring is broken on one side and makes weird sounds. So I searched around here in the forum and find the part no. + an detailed install instruction- but I didn't bookmarked the thread .
Only thing I found is the part no. for the spring + this 2 little bushings :
Spring: 10278874
Bushings: 14046812
EDIT: I found the TSB = TSB 02-07-31-001, FEB 02, Clutch Pedal - Scraping Noise/Return Spring Breaks maybe someone can post the text of it?
but I didn't find the install instructions- so, if someone found this thread or can give me the instructions .
