How bad does this look? (PICS)
I just pulled mine out today too and it looks almost exactly like yours. Are you going to use that same flywheel and get it turned or just get a new one? Thats my dilema.
Jon
Jon
Jon
Jon
I would turn yours for sure.
The wear marks are almost gone on the disc and their is a lot of heat spots on the pressure plate and flywheel . It would work if you are in a pinch but I'd probably replace it if you plan on keeping the car .
haha those look almost as bad as mine. mine was so worn out that my car hardly moved. i had to dump the clutch to get anywhere, and even then it went real slow cause itd slip all the way through every gear, grabbing only slightly. felt like i had a stall lol except it didnt go anywhere
