T56 whine in 5th and 6th under load.
Old 09-24-2007, 11:51 AM
Coup D E'Tat's Avatar
Default T56 whine in 5th and 6th under load.
I have a T56 from an '02 in the Miata, and under load only in 5th and 6th, it whines pretty good. If I let off the throttle, it goes away entirely. Is this normal? It's loud enough that I could imagine it being quite an annoyance on a trip. I was told it may be the rear end (Ford 8.8" from an '03 IRS car,) but it really doesn't sound as if it's coming from there, and as I said, it's only doing it in 5th and 6th it seems.
~3.5 quarts of Synchromesh are in it, and I believe it only has about 42k on it. Shifts fine.
Old 09-24-2007, 12:52 PM
thesource's Avatar
Sounds like the diff to me . The IRS units are well known for making noise and Ford has had alot of issues with the Explorer IRS units . Their solution is to change the ring and pinion but the noise is still there . I believe that diff in that configuration is just noisy . The aluminum housing does not help anything either .
Old 09-24-2007, 02:07 PM
Hm. Any reason why it would do it in 5th and 6th only though? I'll have to take it out again tonight and triple check this, since perhaps in the lower gears (slightly higher RPM,) I just can't hear the whine over the exhaust.
If it is the diff, has anyone tried wrapping it in sound deadening material? Because I sure as heck will be The whine is definitely annoying!
Old 09-24-2007, 06:33 PM
thesource's Avatar
Well 5th and 6th gears are spinning the diff at a much higher speed than the lower gears for one . Typically , a transmission will not stop whining when you let off the gas and most of the time they make noise in 1st-3rd , gets quiet in 4th and then makes noise in 5th-6th . The only time a modern 5 or 6 speed makes noise in 4th gear is if the rear output shaft bearing is bad or maybe the front bearing is toast . That noise is more of a growl and not a whine .
Old 09-25-2007, 08:53 AM
snketr's Avatar
What you are hearing is prob the normal minimal whine. It's just magnified in your car b/c it's a cramped space and you prob don't have any sound deadener to suppress the sounds.
Old 09-25-2007, 09:00 AM
thesource's Avatar
That probably has some to do with it . I would also check the pinion angle on the diff as well and make sure its where you expect it to be . With a shorter drivetrain , you have less margin for error .
Quick Reply: T56 whine in 5th and 6th under load.
