LS7 Clutch guys, in here
I'm having trouble with my car not wanting to go into 1st and sometimes other gears.. I'm trying to narrow down a clutch problem to a hydrolic problem.
If your in gear, at higher RPMs, does your pedal go down from the very top (spongy until about 80-75%, where it feels solid), but is 100% when out of gear?
Fluids brand new, I had my mechanic bleed it AFTER I bled it atleast a bottle and a half. I'm going to Autozone today to get a Mityvac for good measure, and while I'm doing that I'll wrap the lines and re-route the remote bleeder.
The heat shild IS still on there, and I don't have headers on.
Have you done the drill mod on the master yet? That will slow down the fluid flow between the pedal and clutch. I noticed a difference when I did mine while installing the new clutch. No delayed engagement feel anymore. I could feel the clutch grabbing and the car pulling harder as it engaged. Now it is more of an on-off feel. I like that better as it is more positive feeling.
So looks like the votes go for Mityvac and heatwrap?
well i can relate somewhat, i changed my clutch to the LS7 in january, no probs, everything went fine, drove it for about 5,000 miles, then about a month and a half ago clutch wouldnt disengaged, first step, changed the hydraulics, didnt help, next, put in a brand new LS7 clutch, partially solved the problem, i can drive it now but the clutch still does not fully disengage making it hard to get into gear and real hard for reverse, i am stumped on what to, and yes i still have the heat shield over the line and yes the system has been vac bled, i am just drivin' it now cause i got sick of screwin with it, good luck with your dilemma
