T56, oil getting chucked out breather tube
Old 10-04-2007, 03:19 PM
stevieturbo's Avatar
Default T56, oil getting chucked out breather tube
For a couple of years I ran a totally stock T56, overfilled slightly with fluid, and never once did I have a problem.
But this year, with a new built T56, filled with exactly the correct 4 litres, anytime I drive the car hard, Im getting my very expensive oil thrown out of the breather tube.
Any ideas why ?
Old 10-04-2007, 06:11 PM
thesource's Avatar
Do you have the long breather tube like stock or is it a shorter tube like on the vette ?
Old 10-06-2007, 04:57 PM
Both boxes use the full length breather tube, so it does seem very strange that the one with the correct ( lower ) amount of oil, is spewing it out !
Old 10-06-2007, 05:02 PM
ls1 joe's Avatar
Sounds like to much fluid. I know we recommend 4 qts thru the shifter hole. You might try opening the fill plug and draining what excess there is. I know over there the fluid is way more expensive than it is here.
Amber
Old 10-06-2007, 05:18 PM
I could have used cheap fluid if I wanted to. I had been using cheap Fuchs ( they make Silkolene stuff too ) fluid for about 2 years, and it worked perfectly for me.
I was using about 4.5litres, maybe a tad more then.
I just decided to spend more this time around after getting a new trans, and the oil I chose ended up coming from Australia. Although even there, it is expensive compared to other products.
I used exactly 4 litres this time, which is what the factory specs are. Although Most Aussies reccommend overfilling via the reverse light switch with regular oils.
It is not necessary with this oil.
Quick Reply: T56, oil getting chucked out breather tube
