mcleod adj master rebuild ?
Old 10-04-2007, 08:03 PM
kingcuda70's Avatar
Thumbs down mcleod adj master rebuild ?
What function do the (2) stato seals perform on the m a m? I just bought the rebuild kit from Thunder and these seals that are not in the kit were on backorder (~$6 each). I have'nt taken it apart yet. I'm guessing they seal the shaft. I'd just as soon replace them at the same time if they're a wear item even though it's not leaking fluid externally (just air in).
BTW - How does "Red" the president of mclown sleep at night? nearly $50 for this $1.39 collection of crap likely made in china..douchébag
Old 10-04-2007, 09:20 PM
brad8266's Avatar
The rebuild kit contained the exact same parts that came out of my mcleod, no more no less. Im not sure what the stato seals are.
Make sure you bore/hone the cylinder out before you put the new guts in too or else the rebuild will be a waste.
Old 10-05-2007, 11:27 AM
kingcuda70's Avatar
What size hone do I need? Is this due to the edges of the port? Is there an exploded/cutaway view of this POS anywhere?
Thx
NickC
Old 10-05-2007, 12:13 PM
brad8266's Avatar
Thx
NickC
All you need is a master cylinder hone, which you can buy at pepboys, its pretty small and has 3 hone stones/arms on it. In order to make it fit in the cylinder I had to break off one of the arms and hone it with the other 2 stones.
Its really easy to do and you should not need a cutaway to do it. All you do is pull the rubber boot off the rod, then pull the snap ring out and all the guts will then pull right out. Next take your honing tool and hook it up to a drill and put it in the cylinder and hone it till its smooth. You need to get any rough/uneven/pitted surfaces smoothed out. Reassemble the cylinder and make sure it pushes and returns smoothly.
Old 10-05-2007, 10:42 PM
kingcuda70's Avatar
thx brad
Old 10-07-2007, 01:41 PM
LivingCanvas's Avatar
I've often wondered that myself. Worst company ive delt with in the LS1 world
Quick Reply: mcleod adj master rebuild ?
