t56 manual trans?
Old 10-06-2007, 03:52 PM
FASTEST ALL MOTOR LS1 IN THE COUNTRY
CAMN HAWK's Avatar
Default t56 manual trans?
the t56 trans that comes in a gto are they the same as a fbody piece? can get a good deal on a gto trans and wanted to know if they are the same.
thanks in advance.
Old 10-06-2007, 04:05 PM
thesource's Avatar
They will interchange as long as you use your F body shift lever and shifter . Internally the are the same basic trans except the gear ratio and syncro designs are different .
