Six Speeds Inc. 925fwhp @ 9600rpms Naturally Aspirated!!!!
https://ls1tech.com/forums/generation-iv-internal-engine/794352-925-7-9600rpm-flywheel-hp-na.html
We are putting a stock gear set that has been faceplated in and will see what she can take
Amber
Amber
DAYUM!!! That is sooo f'ing sick, I almost don't believe it!!
Until now, I did not think that these engines were capable of spinning that high, regardless of how full race you built them or which valvetrain was used!! (Let alone that they would still be making power up in that range!!)
This MONSTER should shut up the ricer/import fanboyz who think you MUST have 2 overhead cams and 4 valves per cylinder to spin that high (and make power doing it).
GOOD LUCK at the shootout! Could we possibly, eventually see NA, six speed, 7s out of this setup?? That would be TOO MUCH!!!
https://ls1tech.com/forums/showthread.php?t=794352
Amber
Amber
