Master Cylinder ?
Master Cylinder ?
I have a 1998 Z28 and I have the problem where my clutch pedal is stuck to the floor. I understand that the 01 and 02 master is the best replacement for the master. Do you have to change the slave cylinder or anything else or is it just a straight forward swap with the master cylinder? Thanks in advance for the help.
i dont think there is a difference in master cyls, but the 01+ slave cyl is supposed to be better.
i had the same problems. i would bleed the system out and see if that cures it. when i took mine apart the fluid looked like black paint in the slave cyl. i havent had any issues since i put in the newer style slave, a new master, and a new clutch. i figured id do it all in one shot since it was apart.
start with flushing the system out. i bet the pedal will feel much better.
Thanks for your help! I did try replacing the fluid and bleeding the system and the same thing happened again. I was under the impression that there was a difference between the 98-00 and the 01-02 master cylinder? So depending on how soon I can get a new master cylinder I will be trying to replace it over the weekend.
