1st gen LSX/Viper T56 conversion - What VSS do I need?
I have a 30 spline Viper T56 going into a 1st gen behind a 408 LS2. My trans builder modified the tailshaft housing for the VSS and added the reluctor to the shaft, but he can't remember which VSS he did it for (F body, C5, C6, etc.) The dimensions are 1.3" from the mounting face to the wheel teeth (so sensor should be 1.2 to 1.25" reach/depth) 0.7" bored hole (sensor .67-.69" plastic OD around the o-ring), and 0.85" center of sensor bore to center of mounting hole.
Any help would be appreciated. I'm hoping it's not for the 1st/2nd gen Viper sensor ($200-$250).
