URGENT:tranny mount bolt size
Old 10-12-2007, 08:06 PM
chocolatemilk's Avatar
Default URGENT:tranny mount bolt size
anybody know the size of the 2 side bolts for a stock tranny mount???
Old 10-12-2007, 09:00 PM
anybody???
Old 10-13-2007, 09:32 PM
Install Director
wizkid's Avatar
Torque Arm mounts are 15 mm heads on the side of the transmission. There are three bolts. One of them does not have a nut. The two that do have nuts, the nuts are 15mm too.
The center nut on the transmission cross member is 18 mm.
The 4 bolts on the transmission cross member that mount the cross member to the car are 15 mm.
Which one did you need or did I miss it? I gave all sizes for what socket is need for removal. If you need length I can supply that info but thread and pitch I couldn't tell you.
