Clutch Question
Clutch Question
I have a SPEC stage 2 and Billet steel flywheel. My clutch is slipping, and I am going to replace it, I know I will have the flywheel resurfaced, but what about keeping the SPEC pressure plate? can i just get a new clutch disk? can I put a Stage 2+ disk in the stage 2 pressure plate?
Evil, You can buy another disc for use with this plate...but you need to make sure that the plate is still in good shape. Stage 2 is actually quite easy on frictions surfaces as long as it is not heated to Hades and back. Send me some shots of the plate and I will be happy to take a look. Also, you may want to put a machinists straight edge on the disc to check the assembly for flatness too. Let me know what you find. Thanks!!
