clutch line *pics* HELP!
im currently trying to get the clutch line out of the bellhousing and am having lots of difficulty. i've tried the 2 screwdrivers, the disconnect tool, and channel locks...still to no avail, its only making it worse by scratching the hell out of the white part. if you guys could try to help me out...you'd make me very happy
It is not easy sometimes.
I have had to rotate the release ring in times past. It helps considerably if you push the line into the fitting while trying to insert the release ring. A little penetrating oil does not hurt a thing either.
Stay with it, you'll get it!
g
g
I've been trying all day today, but nothing moves at all on that piece. the gold part doesn't go in any farther and if i try to spin the white part everything turns with it. is there something im doing wrong? and with the more I'm trying the more the white piece is getting ripped apart by those screwdrivers
If all else fails isn't there a way to pull the transmission an inch or two, enough to get a tool in there to pull off the slave without disconnecting the line? Think I remember someone saying something about it.
still nothing loosened it about 1/2 turn and still that dam piece does not want to move in, and the more i try the less of the white piece there is, like its breaking apart
If the white clip is pushed all the way in to it's outer lip, then the line should come out. If it isn't, it isn't pushed in all the way.
Like someone said above...push the line in while you are pushing the clip in, which you have to do all the way around. You can lower the tail of the trans some to get more room.
After installing my McLeod bellhousing, slave shims, and new clutch..I actually have to open the bleeder screw to get the line back in cause the system had pressure.
Assuming you are replacing the clutch?
