Do i need a slave shim
Old 10-24-2007, 09:15 PM
m1candelaa1's Avatar
Default Do i need a slave shim
Ok so im going from spec clutch to a RPS stage 4 and a cyn-R-G FW.My question is do i need to leave in the shim that goes behind the slave?I have only used spec clutches in the past and always used them,also my set did not come with an alightment tool, any one know where i can get one/ thanks...
