slave cylinder keeps breaking!!!!!!
i have broken a slave cylinder for the 6th time in 2 or 3 months what can keep causing this problem???? when i jam on it to go 2 a gear that when it breaks and all my fluid leaks out could it be a bad master????i really need some help on this...
wrencher
Well did this start after you changed something?
Did the problem start after a clutch install?
Would have to say that the problem is either the trans/bell alignment, or the pressure plate's installed height.
