Shifter popping out of 2nd gear....
Old 11-04-2007, 12:58 PM
GeneCamaro27's Avatar
Default Shifter popping out of 2nd gear....
My transmission started popping out of 2nd gear yesterday. On the way back from my friend's house it popped out of 4th gear twice. 2nd gear however, is really bad. It will grind and pop out right away. This is all happened under casual driving. I'm kinda bummed out since the car only has 26,000 miles on it and everything has been fine up until now.
Any ideas on what could possibly have caused it to randomly pop out of 2nd like that?
Old 11-04-2007, 01:01 PM
santiago's Avatar
the lil slider keys are broken and need replaced.
Old 11-04-2007, 01:34 PM
Thanks.... I'll look into to it. Should I replace anything else while I'm at it?
Old 11-06-2007, 07:32 PM
santiago's Avatar
no its probably just the keys...get billet keys
Old 11-07-2007, 09:13 AM
ls1 joe's Avatar
I would replace the keys with the billet ones, steel 3/4 fork and do the carbon blocker rings while you have it apart. Make sure you check all of the clearances.
Amber
Old 11-08-2007, 03:44 PM
Amber
I actually just lost 4th gear as well. Same as 2nd gear. I think I will definitely be calling you guys in a week or two, inquiring about your rebuild packages. Thanks for your input.
Quick Reply: Shifter popping out of 2nd gear....
