Clutch master cylinder question?
Originally Posted by nahasapeemapetalon
I think black crap in your resivoir and pedal sticking under accel....
I HAD BOTH THOSE ISSUES...REALLY DARK FLUID AND MY CLUTCH WOULD GET STUCK TO THE FLOOR UPON HARD ACCELERATION OR WHEN I DID A BURNOUT....JUST YESTERDAY I REPLACED IT AND ...WOW.....BIG DIFFERENCE ..VERY NOTICABLE..FEELS LIKE A NEW CAR AGAIN..CANT WAIT TO SEE WHAT SHE RUNS AT THE TRACK
Kleeborp the Moderator™
I'm not sure that the baked (black) fluid can be blamed on the master...that usually happens when the hydraulic line gets too close to the exhaust without being protected from the radiant heat. When you replaced the master, you already had new fluid in it, and that may have been what fixed it...then again, it could have been the master. Who knows...the cheaper way to see if you can fix a suspected master would be to completely flush the system and insulate the hydraulic line completely. If that doesn't work, then go after the master cylinder...if that doesn't do it, it is most likely the slave, which unfortunately is the hardest piece of this puzzle to get to.
Ya if you have those symptoms fix them asap, i htink i toasted my ls7 clutch in 4 months. yea i have heard that boiling crap everywhere, there is acutally sludge on the bottom, im not saying its not possible but noone brought up that it could be the master.
I'm having the same problem with my Firehawk. It shifts fine under part throttle or just cruising, but under full throttle the clutch won't come all the way up. Won't even let me shift or anything. I'm not too good with these things, so I don't know what it can be. My Dad thinks it's either the slave cylinder or master cylinder. Anyone have the same experiences?
