Hard shifting after clutch/flywheel replacement
Old 11-15-2007, 11:28 AM
skipgsxr's Avatar
Default Hard shifting after clutch/flywheel replacement
Last night I installed a spec stage 3+ clutch and spec aluminum flywheel. I blead the clutch and it has a good feel, engauging just before halfway up. but the shifting is very notchy since I installed this. it is especially hard to shift fast. Is this to be expected with this clutch and flywheel? Can I do anything to reduce it?
Old 11-15-2007, 02:17 PM
SPEC-01's Avatar
The release point sounds dead-on...that being said you shouldn't have any issues with shifting. I have to ask...have you done the drill mod? Are the slave and master cylinders new? Let me know and I will be happy to assist you! Thanks,
Old 11-15-2007, 02:42 PM
SS101's Avatar
+1 the rotating parts dont have anything to do with the shift feel
Old 11-15-2007, 05:10 PM
skipgsxr's Avatar
I dont know the drill mod so I have to say no. The slave is new, master is stock. I will look around the forum for the drill mod.
