Throw Our Bearing
Throw Our Bearing
any body replace the throw out bearing only instead of the slave cylinder assy? I replaced mine with a ram and want to know if I can replace the bearing only? how does the bearing come off? if possible?
any help would be appreciated. links/photos/how to's.....
2001 ws6 t56
Thanks
2001 ws6 t56
Thanks
Just looked at a stock slave and the bearing just pops off by pulling it off. Dont know if you can buy just the bearing.Usually just replace the slave/bearing together since you are right there but I know the slave is a pain to bleed at times.
checked it. sure pulls off! I can get the bearing w/ plastic insert at napa. I'll just replace the bearing since I already replaced the slave with a Ram brand.
thanks
thanks
another question.. I have installed a Ram slave and clutch dis-engagement was kinda high. what I mean almost feels like dis-engaging as soon as I press pedal. I did install the spacer on it could that be the cause?? should spacer be in for a 2001 m6?? any help would be appreicated..
thanks
thanks
