Adj Master on Stock Clutch
Ordered a RAM adjust master cyl today. I still have stock clutch, but want to put new master due to pedal on the floor. Should I expect any problems with going to adj master w/ stock clutch?
Can't really see why it'd cause any problems....though I'm not sure I could see a need for an adj. master with a stock clutch....seems like $$$$ that would be best spent elsewhere, for now.
-Will
-Will
You shouldn't expect any problems except the eye part of the master that connects to the pedal will have to be ground down. It's too big for the clip to go around, or at least on mine it was. I've also read some other people have had the same problem.
