View Poll Results: What is your opinion on shimming the ls7 clutch setup?
I shimmed mine and engagement is great.
1
11.11%
I shimmed mine and engagement is to low or high.
0
0%
I didn't shim but engagement is great.
7
77.78%
I didn't shim and engagement is to low or high.
1
11.11%
Voters: 9. You may not vote on this poll
Using a shim with the ls7 clutch kit...
I did not shim mine and it is perfect.
Good info below.
https://ls1tech.com/forums/manual-transmission/816229-all-you-need-know-about-ls7.html
Good info below.
