RAM or Centerforce clutch with SPEC flywheel?
Old 11-22-2007, 11:37 AM
tacklebox's Avatar
Default RAM or Centerforce clutch with SPEC flywheel?
A while ago i picked up a spec 3 clutch and a spec billet steel flywheel, i havent installed them yet, but i think i've reconsidered because i heard that the spec 3 doesnt like to be slipped and isnt too street friendly? Can anybody back that up?
If i end up getting another clutch such as a Powergrip HD or Centerforce DF can i use it with the Spec flywheel without issues? This will be my first LS1 clutch swap i just want to make sure i do it right.
Old 11-22-2007, 12:04 PM
TARZAN's Avatar
Should be able to use the flywheel. Personally, I've had good results with the larger Centerforce DF, but personally, I'd run the Spec 3 since you have it. I've driven them on the street, and theres not too much difference between them and the clutches you listed, as far as manners go
-Will
