Castrol GT LMA Brake Fluid
Old 11-26-2007, 08:24 PM
tee-boy's Avatar
Default Castrol GT LMA Brake Fluid
Anyone using this stuff. It states that it exceeds DOT 3 and DOT 4 specifications. Seems like this would be good stuff for the T56 Hydraulic System.
TYPICAL PROPERTIES*
Test Method Typical Results
Viscosity@ 40°C, cSt ASTM D-445 1100
Boiling Point (ERBP), min °F (°C) SAE J1703 509 (265)
Wet Boiling Point (WERBP), min °F (°C) FMVSS116 311 (155)
Appearance Pale yellow
pH FMVSS116 7.5 to 10.0
Flash Point, COC, min °F (°C) ASTM D-92 250 (121)
Specific Gravity, 60°F ASTM D-1298 1.07
Pounds per Gallon 8.91
