GTO vs F-Body M6 questions...
Old 11-27-2007, 05:37 PM
Johawk's Avatar
Default GTO vs F-Body M6 questions...
Are there any differences between a GTO and a 98+ F-body 6 speed? I guess what Im really asking is, can I swap a GTO M6 into my 98 T/A? Does anyone know if the hydraulics are the same as well?
Old 11-27-2007, 05:38 PM
GasTiresandOil's Avatar
Tail shaft housings are different.
Old 11-27-2007, 05:47 PM
Johawk's Avatar
but if needed I could get a tailshaft housing from any 93-02 f-body... Damn torque arm... Im I correct?
Old 11-27-2007, 06:02 PM
chuckyt1's Avatar
Search for mn12. I think there is a guy on here that put one in recently. It has a different shifter cup but I don't know what all is needed for the swap. Gear ratios ar different also...
Old 11-27-2007, 08:40 PM
ls1 joe's Avatar
Tailshaft housings are the same, the only difference is the offset lever for the shifter. They have the same gear ratio as 01-04 Z06 Corvettes.
Old 11-27-2007, 09:09 PM
Demonicbird00's Avatar
i installed the mn12 in my car back in feb. i love it!!!
-brandon
Old 11-27-2007, 09:33 PM
quiet_storm98's Avatar
-brandon
so is the mn12 stronger or something??
Old 11-27-2007, 09:47 PM
ls1 joe's Avatar
The mn12 has better blocker rings, as in it has triple cone blockers rings in 1st and 2nd, and 3rd, 4th ,5th , and 6th all have double cone blockers. What does this mean you say. It means that you have twice the surface area for the speed gears to be slowed by. Ie faster smoother shifts. A GTO trans will make a huge difference in a bolton F-body, more gear ratio to get the car moving. The mn12 are not any stronger than the normal f-body trans.
Old 11-27-2007, 09:51 PM
o ok thats good to know..thanks
Old 02-21-2009, 10:08 AM
NateZQ8's Avatar
GTO M6 for the win!!
Old 02-23-2009, 07:32 AM
calhoon's Avatar
Holy old post dig-up batman.
Old 02-23-2009, 03:45 PM
bb5401000's Avatar
I recently installed a 2006 GTO tranny in my Camaro. You can bolt the GTO tranny to the Camaro bellhousing and use the Camro starter. If you use the GTO bellhousing, you have to use the GTO starter.
You have to swap over the Camaro offset lever, but the tailhousings are are the same.
Quick Reply: GTO vs F-Body M6 questions...
