anybody w/ dual friction Centerforce clutch
I've got an 02 WS6 M6 . I put in a dual friction clutch / flywheel a few months back and have noticed that when im shifting at higher rpm's the tranny wants to hang up somewhat. It seems like it hangs up when shifting out of the gear and it has done it since it was new and drives and engages excelently other than at high rpms. I've also noticed after running the car hard a couple of time the pedal feels like its losing pressure and hags closer to the floor, but if u pump it a time or two its back to normal. Could i just need to install the shim kit to fix this problem or is this just a trait of the Centerforce . All hydraulics are new and even did the drill mod on the master cylinder can u guys think of anything else it could be or that i need to check or possible solutions if anybody else has had this problem.
Thanks
Thanks
Mine does the same thing hangs up and dont wanna shift. I'm about to put a spec 4 back in. I had the spec 4 before I swapped it to a auto. I loved that clutch! Center force is Junk!!!!!!!!!
is it the 11" or 12" version? Did you replace your pilot bearing when you did the install? I had the same problem when i installed my first centerforce and it was all because i didnt replace the pilot bearing and didnt have the clutch and flywheel balanced together. It ended up throwing my clutch out of balance and the "weights" on the clutch had to compensate for the balance problem. Thanks to the weights being so far off i couldnt shift at high rpms. I contacted Will Baty with Centerforce on this site and told him about my problem. He was VERY helpful and when i got my new centerforce/flywheel combo i made sure they were balanced and replaced the pilot bearing. Now it shifts like a dream!
I LOVE my centerforce!
Brent
Brent
Brent
Brent
Brent
I have the 12" version. I love everything about this clutch. I have not once since installing this one had a problem.(with new pilot bearing, throwout bearing, and having the clutch/flywheel balanced) I have put about 15,000 miles on this clutch so far and it still holds and feels like it did brand new! I drive in stop and go traffic when i am up here for school, give it hell on those late night fun runs, and have made probably 40 passes at the track with street tires and Mickey Thompson Drag Radials. I have slipped the clutch at the track every pass to save my 10 bolt. This thing is solid. I would definately buy one again.
Brent
Brent
Does this clutch disk you guys have have marcels, or are the facings mounted flat on the disk? Marcels are the springy or spongey things between the facings and the disk that reduce chatter and the harshness of the clutch in general. If the macels are to tall then the disk will drag, a disk without marcels should not even come close to dragging since it wont be as spongey. All OEM disks or close to stock disks have marcels.
sorry for the confusion.......when i bought my first centerforce i only bought the clutch and reused my stock flywheel (got it turned). I didnt get those 2 balanced together like an idiot.. When i got the clutch/flywheel combo from centerforce it was balanced together.
Brent
Brent
Brent
clutch pedal is pretty close to stock. It releases almost like stock too. Its not as close to stock as a LS7 clutch but it is definately better than a Spec! The centerforce will handle a little "slipping", its not a "on/off" clutch like some of the others.
Brent
Brent
I have the 12" and I've had great results...purchased the clutch/pp/flywheel all from Centerforce at once, installed a new slave and McLeod Ajd. Master at the same time, have had no problems...
-Will
-Will
