Clutch Problem..help Me!
02 camaro ss. Just got my new clutch built, its a big one. Got everything back together and went to bleed the clutch out. Clutch finally got stiff, but now, once you get halfway down, it gives out and goes to the floor and fluid blows out of the slave cylinder inside the tranny. Any opinions
aight. i know the bleeder screw is tight, but i will pull the slave again. i just dont understand why it doesnt leak until the pedal is halfway down
If fluid is pouring out of the Bell-housing then it is very likely a cracked slave. The only you can do at this point is pull the trans and check things out. There isn't really any way to repair the slave...you will simply need to get a new one. Make sure that you get the appropriate part for your car though, as there are a few different slave cyllinders being sold by Chevy at this time. Let me know if you have any further questions. Thanks!
i got a bad pressure plate. The center was staying pushed in and wasnt releasing, therefore, as i pumped and pumped and pumped, the throwout bearing was already pushed all the way out resulting in blowing the seal out.
