Is there anything else I need to change...
Old 12-02-2007, 08:50 PM
protouring70's Avatar
Default Is there anything else I need to change...
I am going to replace my clutch. Is there anything else I need to replace during this?
And also where is the best place to order a Spec clutch?
Thanks, Brent
Old 12-03-2007, 09:04 AM
teke184's Avatar
year car
miles
mods
considering how much of a PITA it is to pull the trans, i would just go ahead and put in a new slave cylinder. and a pilot bearing.
you'll have to either resurface the stock flywheel or put in a new one. steel for drag racing, aluminum for autoX.
i'm very happy with my adjustable master cylinder from RAM. and i did the drill mod to the line while it was out.
Old 12-03-2007, 11:00 AM
PewterScreaminMach's Avatar
X2. Do exactly what the previous poster said.
Old 12-03-2007, 02:46 PM
Mike44138's Avatar
If you resurface the flywheel make sure you shim to compensate for how much they take off. Also its usually not necessary but to be safe I'd have the flywheel and pressure plate balanced.
Old 12-03-2007, 10:22 PM
caged02's Avatar
Order your SPEC through the WS6 store, good price and fast shipping.
Old 12-03-2007, 11:08 PM
Yowzerman's Avatar
A remote bleeder line for your clutch is a must since you're in there. Not sure of your clutch line but depending, a SS hard line from the master to the slave could also be beneficial.
Tom.
Old 12-04-2007, 05:48 PM
Thanks for all the help!!!!
