im having clutch and pedal problems i need help plz????
well ive just put a new slave and , master in and i have a stock o'reils clutch in with about 700 miles on it well i had it in there before i installed the new slave and master... i have to pump the clutch several times before i could put it in first and i have to pump it to go to the other gears and when the car is off i pump it and the pressure builds up fine in the pedal but once the car is running the pressure isnt there and the car would start rolling if its in gear... need help real bad
