twin spec clutch please chime in
Old 12-09-2007, 04:54 PM
leo72519's Avatar
Default twin spec clutch please chime in
who is running the twin organic/cavlar spec?...please give you in put...i am in the market for a clutch and so far its between the ram and spec...
Old 12-10-2007, 12:10 AM
black98ws6ta's Avatar
I am interested as well, got a 1000 rwhp c5 and want a clutch that will hold more then the tires. I hear alot of good and bad stories about textrilla.
Old 12-10-2007, 12:14 AM
ninetres's Avatar
Oh, well then you need that one clutch.........what's it called???? Oh yes, a TH400!
Old 12-10-2007, 12:18 AM
Been there done that, customer likes shifting.
Old 12-10-2007, 12:24 AM
ninetres's Avatar
RMVB
I know, I know. I do miss REAL shifting too. But its tough to shift a manual when the clutch burns up every other month.
Old 12-10-2007, 12:26 AM
Somebody makes one that will hold...esp with this car running around on small radials.
Old 12-10-2007, 06:27 AM
speedracer5532's Avatar
I ran the Exo-skel with 1000 rwhp and it slipped on me so I switched to the Spec twin disk stage 2 and it holds great and driveability is excellent.
Old 12-10-2007, 07:58 AM
LS1Tech Sponsor
Slowhawk's Avatar
I run 2 SPEC duals in friends cars.They are the carbon,hold very good and little to no chatter. To date they are the best clutch we've ever used for drivability and holding power. I car has had it 2 years holding 840hp/820tq on pretty much a DD car.Another has a blown 427ci Vette with probly 60 track passes and alot of street miles. Both of those cars bvlew almost every clutch out there and went through 2 clutches a year before these.
Old 12-10-2007, 10:04 AM
52172's Avatar
Sounds like the SPEC twin is the best out there.
Old 12-10-2007, 10:33 AM
MY99TAWS6's Avatar
Do the spec twins use stock master and slave?Do they require any shimming?
Do they have floater rattle when you push in the clutch?
I have a exoskel as you can see from my sig but only at 420 engine hp or so my turbos and new engine are not installed in my car yet. I was thinking of going to the triple tex maybe but also hearing from some guys that say it has /will hold the power and some like in this thread that say it didn't. The tex twin pedal pressure is fine, the rattling when clutch is pushed in is slightly annoying but of course it has to hold the power I need it to hold which should be around 1000rwhp max with turbos and some spray.Driveability is so so with the tex.Could be better. They offer some more street able discs but they also take even less power so not the best idea unless maybe in triple disc form.
Couple buddies have spec 3s. One has had his for quite a long time and is very happy with it and the other one just got his in and I drove it and it seemed pretty streetable. Not sure how much a spec 3 plus can really hold.
Old 12-10-2007, 10:36 AM
52172's Avatar
3+ is rated to around 850 Trq which is much more than the three and close, but not as high as the 5.
Old 12-10-2007, 11:41 AM
2000 Tran Zam's Avatar
im running mcleod twin disk... it burnt up once but held the power fine after that. they have an upgrade that holds like 1500 or 1600hp/tq so that could be an option too.
Old 12-10-2007, 03:28 PM
Firechikn's Avatar
My spec 5 is starting to act up. I'm debating on a new 5 or the twin. As cheap as the 5 is, I would try another one. I don't mind spending the cash for the twin as long as it would hold. Good info slowhawk, because mine is mostly street driven, not a DD though.
Old 12-10-2007, 06:26 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
A lot of people are having issues with the spec twin.
https://ls1tech.com/forums/showthrea...584&highlight=
Old 12-11-2007, 08:32 AM
LS1TECH Sponsor
Jonathan@Tick's Avatar
We installed on in an 01 SS and had the same problems as mentioned in the thread linked above. The actual measurement from the crank surface to the pp fingers when the pp was torqued down was roughly 1/4" more than the factory LS1 clutch. This caused the clutch to start slipping almost immediatly behind a 550 rwhp SS. The slave was actually bottoming out and actually riding the pp 1/8" at all times. This was on an LS1 car, not an LS2 for those that have read the other thread.
Spec did take care of the problem but they wouldn't pay the shipping for us to send back, much less our labor to install it twice. It seems to be working fine now.
Old 12-11-2007, 10:50 AM
SPEC-01's Avatar
The issues outlined in the linked post were related to differences in bearing depth (specifically in regards to those with GTO's or using GTO bearings). As a result we have updated the part numbers to reflect the parts needed. That being said we have had no other issues and the customers that had problems have been taken care of. Let me know if you all have any further questions. Thanks!!!
Old 12-11-2007, 11:19 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
i have a question.why not just become a sponsor so u can actually post about the company and help people openly and share youre products and such.
Old 12-11-2007, 03:04 PM
Mike 01WS6's Avatar
Spec 5 here.
Old 12-11-2007, 03:22 PM
SPEC-01's Avatar
We have actually emailed the folks that run the sight about sponsoring the site next year but we have not received any email in return with info. I would love to sponsor the site...but I need someone to get back in touch with us so we can!!!
Old 12-11-2007, 07:04 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Sent you a private message with the new sales team contact info. Thanks
