What tool for Slave Bleeder Bolt?
I tried using a 7/16 inch socket in quarter drive and short extension to bleed the at the slave, but it won't fit over the bleeder valve.
What tool should I be using?
I used a 1/4" drive deep well 12mm last night when I did mine. I couldn't get a 7/16 to work either. I also drilled a hole through the floor pan to access it though. Might want to consider the access hole.
