weird problem with my pro 5.0
Old 12-10-2007, 09:00 PM
Art Vandaley's Avatar
Default weird problem with my pro 5.0
I don't know if anyone elses pro 5.0 is like this but it sits way to close to the right side. What i mean is like 1st looks like 3rd and 2nd like 4th. I know everything is sitting the right way. I have the lss on it now. Should I get a short stick that angled?
Old 12-11-2007, 12:48 AM
jmdale1984's Avatar
I dunno... but it seems like ever since I put the poly tranny mount in my car, my stock hurst shifter has set way too far to the passenger's side. Do you have a poly tranny mount? Could have something to do with that.
Old 12-11-2007, 01:17 AM
wrencher
wrencher's Avatar
I used the angled stick that came w/ the 5.0. I just cut it down to shorten it up some, there is plenty of thread on there to do so.
The strait sticks dont work IMO one this set up.
Old 12-11-2007, 11:46 AM
I just got the the shifter, i bought it used without the original stick. does anyone else have this problem with the pro 5.0? thanks for the replys
Old 12-11-2007, 11:57 AM
00PEWTERmaroz28's Avatar
I just installed a pro 5.0 in mr car. and by lss I believe you mean Lou's short stick right? If so I just installed both of those on my z28 and love it. you may have the lss backwards?
Old 12-12-2007, 01:17 AM
wrencher
wrencher's Avatar
I have seen plenty of the strait style short sticks. I would get an angled one then, they are avaliable.
Old 12-12-2007, 11:50 AM
the know the lss (lou short stick) is on the right way. here is a picture looking above the shifter. when this pic was taken i had the speed inc angled short stick then i took that out and put the regular lou short stick. I was thinking about buying the angled lou's short stick for the pro 5.0 on afterthoughtsauto.com
Old 12-12-2007, 11:56 AM
here is first gear
second gear
third gear
fourth gear
fifth
sixth
Old 12-12-2007, 01:05 PM
02NBMWS6's Avatar
Mine sits way over to the right with the straight stick on it, but it doesnt bother me. I just got used to it.
I always thought the shift ***** that were angled towards the driver looked a little weird..
Old 12-12-2007, 05:18 PM
jimbo98z's Avatar
That's really weird, I'd like to know what's going on for curiosity's sake.
Old 12-12-2007, 05:49 PM
lol. its weird right. i know its installed right. guess i have to get used to it or go back to the hurst or something.
Old 12-12-2007, 06:10 PM
02silvaZ's Avatar
good luck, never seen one like that, hope it works out for ya
Old 12-12-2007, 07:46 PM
someone have a picture like mine to show where its suppose to be at?
Old 12-12-2007, 10:25 PM
93blcZ28's Avatar
mine the same way, bugged the **** out of me a first! never figured out why tho, just have gotton used to it. have a hurst short stick i think is the one that comes stock with the hurst package for a ss
Old 12-12-2007, 10:27 PM
93blcZ28's Avatar
btw, how the **** did you get the rubber boot off without cuting it? mine got all fucked up lol
Old 12-12-2007, 10:34 PM
ssman00's Avatar
the pro 5.0 stick has an angle cut on the bottom of it that makes it set dead center the prob is you arent using the stick that comes with them. Juat get a stick that is designed to work with the pro 5.0. i have the pro 5.0 and the correct stick but a buddy of mine had the same prob you guys do and he just got a pro 5.0 stick and it corrected it fully
Old 12-13-2007, 01:31 AM
5w20's Avatar
change your short stick
Old 12-13-2007, 10:31 AM
alright, does anyone know where i can pick up the original pro 5.0 stick?
thanks guys for all the help!
Old 12-13-2007, 02:33 PM
5w20's Avatar
Might also want to check if your console is installed correctly where the two 10mm bolts are at the very front, they have tabs. Make sure both tabs are on the outside.
Quick Reply: weird problem with my pro 5.0
