Symptoms of running low on tranny fluid? 6 speed
Whining in all gears, possible grinding while not usually a major symptom since that could be alot of other things.
Most people know since the whine wil start low and then get alot louder. The more you drive it the more damage it is doing since it eats the heat treat off the gears. We see it way to often.
Amber
Amber
