LS7 clutch/LS2 flywheel combo?
Ok, My clutch pedal is stuck to the floor....There was no fluid in the resevoir when I checked so I have a leak somewhere. Im thinking it's probably leaking in the master cylinder. I am going to check tomorrow and then possibly replace the master cylinder.
However if it turns out to be a slave cylinder I am going to swap the clutch/flywheel.
I want to stay under 500 for the clutch.
Should I go with the LS7 clutch / LS2 flywheel combo
or a spec stage 2 with resurfaced stock ls1 flywheel
This is for my 02 WS.6 FYI
I bought it a couple of months ago, but my LS7/LS2 clutch kit was $399.99 from sdpc (sponsor). http://www.sdparts.com/
I can't find it at the moment.. But it should be in there somewhere.
http://www.sdparts.com/product/SDLS7...cFlywheel.aspx
There's the link to the clutch on SDCP, I've heard good things about the LS7 clutches for street cars. I plan to get one when I upgrade mine.
