Hard reverse after head/cam.Why??
Old 01-15-2008, 09:31 AM
408Maro's Avatar
Default Hard reverse after head/cam.Why??
ok so i just finished my heads/cam swap and now my tranny dont want to go into reverse. i have to force it hard to get in. this is with the car on or off. why?? any thoughts?? clutch is fine all other gears are good as well
Old 01-15-2008, 09:36 AM
mattraypharbor's Avatar
do you have an a4 or a m6? if its an a4 is it stalled? and you do know if its not ur cam is useless imo and i could give you a few thoughts about why its sticking but if it is an m6 im not to savee..
Old 01-15-2008, 09:40 AM
408Maro's Avatar
its a m6 and i have a ms4
Old 01-15-2008, 09:45 AM
Jon5212's Avatar
Did you bump the reverse lockout solenoid or take the plug out of the transmission?
Old 01-15-2008, 09:48 AM
408Maro's Avatar
i didnt touch nothing on the tranny,but just in case where is it located? thanks
Old 01-15-2008, 10:00 AM
Jon5212's Avatar
It's on the right(passenger) side, there are 2 solenoids, one is the Cags and one is reverse lockout... solenoid may have just gone bad, or maybe a short in the wiring. Thats the only thing i can think of if this is the first time it's happened and all the other gears are fine.
Old 01-15-2008, 01:01 PM
brad8266's Avatar
Its likely the reverse lockout solenoid. Either its unplugged or the " ENG SENS" fuse simply blew out. Id check that fuse first.
Old 01-15-2008, 07:15 PM
408Maro's Avatar
ill give thos a shot, thanks guys
