"How to" for Drill mod??
Tough Mudder
Careful you don't drill too far past the little metal clip. I must have nicked the inner wall of the braided line because I noticed it weeping fluid while I was bench bleeding it. I took it to Bearing Supply (a local shop) and had them cut off the ends and attach them to another braided / nylon lined line. Cost me $18, could have been a lot worse.
At least I know for damn sure there's no more restriction.
Here's the link to the sticky at the top. Theres a link towards the bottom in the first post with a link to the write-up on the drill mod.
https://ls1tech.com/forums/manual-transmission/742741-sticking-clutch-pedal-write-up.html
