04 Z06 clutch problem..
need some help/advice on a 2004 Z06 clutch problems.. did some searching but couldnt come up with anything..we installed a textralia oz700 clutch with flywheel, new rebuilt tranny and a DTE rear end.. car was broken in for a little over 600 miles already and then this happened: the car when off will go thru all gears including reverse, but when we turn it on when we shift towards first gear(not all the way in 1st), the car gives a little hop forward, and it's kinda hard to put it in reverse.. i was told the hydraulic system might have some air in it but we already bled it like 30 times.. can someone please input on this..
alright gonna try the master cylinder first.. i had a feeling it was going to be the master since it was the only thing we didnt change.. thanx alot for you all's help.. i'll keep y'all updated
