Tips for hillbilly tranny removal...
Well Im sure plenty of you guys have pulled trannys without the proper tools. What are some tips for a garage job? I have some pretty tall jack stands with a decent jack but no tranny jack. Also doin the rearend at the same time but that shouldnt be too difficult. Any help would be appreciated.
Thanks,
Erik
Thanks,
Erik
Getting some LONG *** extensions to remove the top bolts from the tranny to the bellhousing will come in very handy. If you have the car high enough, a regular or low-profile jack will be helpful when dropping the tranny as it's pretty heavy, especially when you're on your back. I recommend having a friend with you.
Internet Mechanic
yeah they weigh about 175-200 without fluid, i just yanked it out let it down on my chest and rolled it off... not too bad, just get it as high as you can on the stands and yeah u are gonna need some long extensions. if you dont know already it is a shitload easier if you separate the trans from the bell housing first
The Harbor Freight Transmission Jack is very inexpensive and greatly simplifies the job.
http://www.harborfreight.com/cpi/cta...emnumber=39178
well you just have to use common sense, if you can bench 175-200 at least you will be fine. i would reccomend having a friend, but if you need it out and your alone you should be okay...
Thanks guys,
Benching it down shouldnt be a problem. Gettin it back up might be. First thing though is cleanin the damn garage. I hate losing things under trash or paper towels. Stuff rolls under damn things 20ft away when it could just stay where it should... oh well. If I need to I could prob rig the jack to get it back up in place.
gettin it back up requires some finesse, i usually just put a piece of wood on my jack plate to keep it even when im jacking it up, you might wanna use just a little bit of grease on the dowel pins so the bell housing isnt such a bitch to get off next time.
don't let this guy think he can do it if he can't, they weight more than 135 for sure buddy
