400-500hp, need new tranny
iam gonan drop a 400+ carbed 383 into my 92 rs, i want a manual tranny, are there anyways to beef up the t5 to make it handle more power? id love to have a t56 but those are really hard to find down in louisiana, by the way will a t56 bolt up to just about any 350? and how would i go about finding the right rear end for the car, will a 4th gen z28 bolt right up and handle the power iam gonna throw at it? this isnt exactly a daily driver, kinda more of a go out on the weekends tear up the street and strip but also be about to take a cruise around the town with the other cars from the area
First question you asked the answer is yes.
No the t56 from a 4gen will not bolt right up need and adapter. but it will handle a 400hp motor. You can go about find the right axle by seeing how much your pocket book can handle. If you have the money for a new rear go ford 9 inch.
Actually a LT1 T56 will bolt up. I think there are a few things to keep in mind but for the most part, it will work. The LS1 T56 uses a push setup while the LT1 uses the older pull style.
Tremec TKO, i have heard of those before btu i dont knwo much about them, where can i go to find a price? aslo are those 6 speeds and as for the rear end its w/e came in the 92 rs its got the 305, so could i just thrown any posi into it or what
The diff in your car is basically the same one as the later 4th gen cars with the exception of the center carrier . Its one of the weak links you will be faced with later down the road . With a 383 in place , you should be able to use either the TKO or T56 fairly well . Both are going to have their challenges both in installation and in cost . It will be far cheaper to install a nicely built 700R4 instead but what fun is that right ????
I did an 82 Firebird for a customer a few years ago with a 383 SBC making about the same power you want and did a T56 in it as well . It ran pretty decent but ended up costing a pretty penny before it was said and done .
