please help. master cylinder ?
Old 02-18-2008, 07:42 PM
2001AntiVenom's Avatar
Default please help. master cylinder ?
Alright i pulled my master out to do the drill mod and adjustable mod. everything went good but when i was cleaning the master the inner slip came out. when i got it all put back together it leaked from where the little clip that holds everything in. I pulled it apart and all the seals look good. am i doing something wrong? anyone else have this problem?
Old 02-18-2008, 08:37 PM
chuckyt1's Avatar
Bench bleed it and then check it for leaks... I did the adj mod on mine with no problems.
