Clutch grabs when I rev
like the title says, I have a 98 trans am and when I rev it the car lurches forward even when the clutch is slammed into the ground, someone help!!!!
Clutch is dragging. You can do some damage to the tranny driving it like that. I'd start with bleeding the system and see if that helps. Search fot Ranger, he has a good sight about maintaining clutch fluid.
this was a recent issue, the previous owner had an aftermarket clutch on it and i talked to him on saturday, he said he had no issue with it doing that. im trying to bleed it tomarrow and ill post with results.
11Second Club
Troubleshoot in this order. If you're gonna do 4, you might as well do 5, too.
1) Flush and bleed the fluid.
2) Do the drill mod.
3) Replace the master cylinder.
4) Replace the slave cylinder.
5) Replace the clutch.
so i bled the system today, it seemed to work at first but after a couple of minutes i had the same problem. it smells like crap but it isnt as bad, i am going to try to powerbleed it tomarrow and maybe try the drill mod. anyone have any pictures/write up on drill mod. i tried a search, not pictures tho, the one on install university is confusing so if anyone had any pictures that would be awsome.
