What fluid should I use in my T-56 as per Tremec techincal support
Old 06-25-2010, 05:00 AM
  #61
SimRacer1's Avatar
are the penzoil synchromesh, mobil 1 ATF and GM Synchromesh all NON Synthetic?
Old 06-25-2010, 09:24 AM
  #62
LS14EVR's Avatar
mobil 1 ATF that I used was synthetic
Old 08-27-2011, 06:24 PM
  #63
Carlos01SS's Avatar
okay this was quite a while back on z28.com but a mechanic over there, his name was Rob aka Poltergeist SWORE that the Borg-Warner/Tremec T56's LOVED Honda ATF, I've used that ever since and after 100-150 miles sucker shifted real slick and I LOVED it.
Right now I got RP in it and it's not good, hard to shift in higher RPM's so I'm going to switch back to Honda ATF
Old 08-29-2011, 01:01 AM
  #64
Jeff Smith's Avatar
LOL I never heard of Honda atf. Good works?
Old 10-09-2011, 04:44 PM
  #65
Suzaku's Avatar
Here's an update for my experience with other fluids, since I believe this is a very important thread. I just replaced my old dexron iii and put Mobil 1 Synthetic ATF into my T56 because I couldn't find dexron iii or synchromesh anywhere, and now it grinds in every gear when you shift hard. Of course this might be being caused by the fact that it is currently winter or the fluid might not be broken in? (Doesn't make sense, but I'm trying to find a reason why it's causing grinding). In anycase, I'm going to stay away from Mobil 1 Synthetic ATF from now on.
Old 05-07-2015, 11:57 AM
  #66
02ws666's Avatar
OK so per Tremec we should be using Dexron III... However when I went to OReily to get some fluid, it was branded as Automatic Transmission Fluid... Is this correct?!?!
This is what they had, and it states AUto on the bottle.. Is this ok?
http://www.valvoline.com/products/co...ssion-fluid/33
Last thing I want to do is to put the wrong fluid in
Old 05-08-2015, 10:52 AM
  #67
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Yes. Although I would personally get the AC Delco stuff.
Andrew
Old 05-08-2015, 10:46 PM
  #68
jmd
jmd's Avatar
Yes. Dexron III automatic transmission fluid is correct.
Old 05-09-2015, 03:15 PM
  #69
whatsa347's Avatar
So pretty much what I've gotten from this thread and a bunch of others, is southern climate use synchromesh, upper climate dex 3?
Old 05-13-2015, 04:53 PM
  #70
02ws666's Avatar
Andrew
Thanks guys! Shifts like a dream!
Old 05-17-2015, 05:12 PM
  #71
SWRocket's Avatar
How much quarters or liters goes in a empty gearbox guys?
Mine is a T56 6spd and I bring it from ship, so it's empty like new...
Thanks
Old 05-17-2015, 06:38 PM
  #72
dailydriver's Avatar
Thanks
4 liters will be spilling out of the fill hole, if you try to put ALL of them in, even with the car jacked up on the side of the fill hole, let alone with the car level on a lift.
I would stop at 3.75 liters or so.
Old 05-17-2015, 08:42 PM
  #73
SWRocket's Avatar
Thanks man!
Old 06-13-2015, 05:54 PM
  #74
wayland1985's Avatar
Digging this back up!
Any verdicts out there yet? dexron III only appears to be available around here as store brands (Advance, oreillys, etc).
Old 06-13-2015, 05:56 PM
  #75
Amazon
Andrew
Old 06-14-2015, 03:15 AM
  #76
Carlos01SS's Avatar
My tranny was just rebuilt and the shop swears on the Mobil 1 synthetic, but basically I got a brand new tranny at this point.
Adding Mobil 1 synthetic to an older tranny may **** up the gaskets like it does when switching to synthetic on higher mileage LS motors?
Old 06-14-2015, 10:38 AM
  #77
jmd
jmd's Avatar
Hey Carlos.
The ultra RTV used for case sealing and the few o-rings and seals will be fine with any of the ATFs.
Old 06-14-2015, 09:38 PM
  #78
So I see a castrol dex-merc and cal online dex-merc.... But there's also AC delco 88861800
I live in New England so cold weather is a possibility so I'm hesitant to use synthetic
Old 06-14-2015, 10:03 PM
  #79
I bought 5 quarts of this:
Amazon.com: ACDelco 10-4033 Manual Transmission Fluid - 1 qt: Automotive Amazon.com: ACDelco 10-4033 Manual Transmission Fluid - 1 qt: Automotive
Andrew
Old 06-15-2015, 12:17 PM
  #80
Firebrian's Avatar
Doesn't appear to be ATF. Just plain old manual trans fluid. AC Delco does offer an ATF III.
Quick Reply: What fluid should I use in my T-56 as per Tremec techincal support
