Do my longtubes have to be loosened to remove trans for clutch swap?
Old 02-26-2008, 09:49 PM
soontobeLS1's Avatar
Default Do my longtubes have to be loosened to remove trans for clutch swap?
As the title says.....just curious as I am having a new clutch installed next week.
Thx.
Old 02-26-2008, 10:55 PM
99ws9's Avatar
I just replaced my trans and we didn't have to touch any exhaust components. If you have a 3" y-pipe then it will make removal a little more annoying but the longtubes won't be in the way anymore than the stock exhaust would be.
Old 02-26-2008, 11:48 PM
2002camaross35th's Avatar
I agree...The only thing i had to remove was the Y pipe as far as the exhaust goes. Here is a write up to help you out http://www.installuniversity.com/ins...sity/index.htm
Old 02-27-2008, 03:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Yeah, the x portion is all that I had to take off on mine. The headers are actually where I would slide the extensions I use when I got the top bolts out of the bellhousing.
