Is my flywheel ok?
Is my flywheel ok?
I recently replaced my clutch (less than 500 miles ago) and then had transmission problems. I just pulled my clutch off to see if everything was ok since the transmission was out. I had the flywheel resurfaced before the install. It's a spec steel flywheel.
I'll try to insert a link.
Thanks
http://pictures.aol.com/galleries/bl...yxGauyHwmH**W4
Thanks
