input shaft bearing
Old 03-14-2008, 02:20 PM
97badass's Avatar
Exclamation input shaft bearing
ok ive spent hours searching on here and google to no avail. does anyone have any idea how to get the "pocket" bearing race out of the input shaft. its the bearing that goes between the input shaft and the mainshaft. i got the bearing changed on the mainshaft but i cant get that ****ing race out of the input shaft. any suggestions would be greatly appreciated. thanks and preferably soon...i would like my transmission done pretty quick. thanks
Old 03-14-2008, 03:03 PM
ROCNDAV's Avatar
using a press and different sized bearing separators is what worked for me.
IIRC, I had to break the old bearing apart (or maybe it just did, trying to pull it) and once I was just messing with the inner piece I was able to get it off.
I see why the recommend not changing them unless absolutely necessary.
Old 03-14-2008, 03:12 PM
97badass's Avatar
yeah its that stupid inner piece i cant get out. nothing to grab ahold of it and pull with. and it does need to be changed. this transmission is a pain in the ***! but its all i have left besides the tailshaft bushing to do.
Old 03-14-2008, 03:21 PM
ROCNDAV's Avatar
yeah, I forget what I did, I think I had to grind/cut on one of my bearing separators to get a good bite. I just bought crappy stuff at Harbor Freight, so it wasnt like I was grinding on some expensive Snap on tools.
Good luck with that. I remember I was pretty pissed off!
Old 03-14-2008, 03:40 PM
97badass's Avatar
if i was pissed off id be happy but i just cant get that damn race out of in end of the input shaft. makes me hate my car even more...im already to the point i wanna sell the stupid general mistake pos.
Old 03-14-2008, 03:57 PM
ls1 joe's Avatar
Take a mig welder and put a small bead on it and when it cools it will almost fall out.Or you can cut it out with a carbide and a die grinder.
Old 03-14-2008, 04:02 PM
97badass's Avatar
i have actually thought about both of those ideas...only the welder isnt here at the house. and we done have the other thing also i will be giving Joe a call tomorrow about the tailshaft bushing. thanks i hope to have my car going again soon. i have been without it all winter. im ready for it back.
Old 03-14-2008, 04:05 PM
ROCNDAV's Avatar
Yeah I had to cut out a pilot bearing that wouldn't budge once out of the rear of an engine. I almost cut all the way through, it cracked at the very end.
Old 03-14-2008, 05:06 PM
thesource's Avatar
I don't change them unless they are screwed up but when I do change them I just cut the race in half and smack it with a hammer and chisel .
Old 03-14-2008, 05:24 PM
97badass's Avatar
its deff screwed up. theres surface rust on the race. and im not going to risk ****ing up a newly rebuilt transmission because i didnt change out a $5 bearing race! that thing is coming out one way or another. some how some way some time that thing is coming out SOON. i miss my car, im sick of driving a ford
Old 03-14-2008, 10:01 PM
97badass's Avatar
$20 more 36 cut off wheels and 2 hours later that damn thing is still in there...those stupid little dremel blades snap as fast as you put them on!
Old 03-15-2008, 12:40 PM
ROCNDAV's Avatar
Make sure you buy the thicker ones with the criss-cross thread in it (looks like a real cut off wheel) and not those cheap, thin maroon/brown wheels that snap if you aren't perfectly perpendicular to the thing you are cutting.
Old 03-15-2008, 02:28 PM
97badass's Avatar
yeah those thin pos suck i spent more time changing them than i did cutting, but small town small hardware store, it was the best i could do.
Old 03-15-2008, 03:29 PM
forgedlt4's Avatar
ah, your using a dremel tool.... those are next to worthless. id pick up a cheap air-powered die grinder. easier to use, and parts are also cheaper.
Old 03-16-2008, 03:30 AM
97badass's Avatar
race is out ready for a new one in the morning then the transmission will be going almost all the way back together on monday! then after the foot of snow is gone then its lay in the mud and put the tranny in.
