T56 Problem
Old 03-20-2008, 09:38 PM
Cmhatter9SS's Avatar
Default T56 Problem
First my clutch fuild is pretty dark. I have updated Hydros, LS2 Flywheel LS7 Clutch about 12k on them both. My Pedal Releases really low to from the floor and sometimes if I am sitting at a light and I am out of gear it is hard to push 1st in also the same for 1st 2nd 3rd 4th and 5th. But not all the time sometimes the gears gride. I know it aint the trans it has 12k on it all rebuilt with steel 3rd 4th keys and all that good stuff. It was built by a corvette Spec that builds 9 sec vettes does anyone have any ideas? I am about to change my fluid to Dot 4 and heat tape. To see if that works let me know thanks
Old 03-20-2008, 09:49 PM
chuckyt1's Avatar
Flush and bleed the hydraulic fluid. Search for ranger on here, he has a good sight about clutch fluid maintenance
