ram hd questions
Old 03-24-2008, 07:19 AM
ls1leadfoot's Avatar
Question ram hd questions
i recently did a t56 swap into my camaro
everything is smooth except that the clutch is all the way at the floor when it engages and disengages.....YES i do have a adjustable m/s and have it adjusted all the way out.....and the spacer is behind the slave cylinder also.....
does the clutch need to be blead more or is something wrong???
Old 03-25-2008, 06:12 AM
after reading other posts.....might have to bleed it another 20 time....hah
any other ideas guys??
Old 03-26-2008, 10:02 AM
BlackSS2001's Avatar
What adj. master cylinder do you have?
Old 03-27-2008, 12:02 PM
i have the ram adj ms
Old 03-27-2008, 02:18 PM
PewterScreaminMach's Avatar
I would continue to bleed it some more before trying anything else. It could definitely cause your problem and it can be very difficult to get all the air out of the system if that is the case.
Old 03-28-2008, 01:40 PM
right on man.....i bled a couple more times on thursday......came about 3/4 of an inch further from the floor
