Pilot bearing prob...
This is my 4th clutch change on this car and the first time with this problem. I put in the bearing removal tool like the other times, but this time the tool more or less pulled out the rollers and inner part of the bearing but the bearing did not budge. I searched and found some guys cut it out. How do you do that and are there any other methods??
thanks
thanks
thanks
thanks
Thanks guys... what was happening was the Snap-on (great tools) puller was grabbing the bearing not the entire housing. I finally tore out most of the bearing and chiseled out the rest then the puller could grab the bearing housing. Never had that problem the last 3 times. Dunno why it got so stuck.
thanks again
thanks again
Thats not bad for a car 7 years old. I only blew the Ram and thats what just the clutch itself. The Tex gave me almost 2 years and the First Spec a year 14k I think. I always get mixed up.
i had the same problem and tried every idea. nothing worked. i justed picked up the pilot bearing puller put it back in tighten it with some channel locks on the pin thing and prayed and it came it also brung the back freeze plug or whatever its called with it but it came
