tranny gurus...5th gear needs help?!?
Old 04-03-2008, 11:09 AM
blu98ta's Avatar
Default tranny gurus...5th gear needs help?!?
I can't shift into 5th gear. When I try to put it in 5th it grinds and wont actually ever engage in 5th. The grind does not sound like a missed shift though. I can actually leave the shifter almost all the way in 5th without pulling it back to neutral, but it never engages 5th. Do yall think it is the 5th gear, or synchro, or what? When I get my tax return back, I am gonna fix it, but want an idea on what it is. Any ideas??
Old 04-03-2008, 12:00 PM
blu98ta's Avatar
anyone have any ideas?
Old 04-03-2008, 03:19 PM
blu98ta's Avatar
Ttt....
Old 04-03-2008, 04:12 PM
900hpSS's Avatar
Sounds like the dog teeth on the blocker ring and possibly the 5th gear teeth as well. the teeth get rounded off and then the gear won't stay in guaged. In your case they may be rounded off bad enough that it won't hold in gear at all.
Old 04-03-2008, 05:05 PM
blu98ta's Avatar
It never actually goes into gear. Could it be the syncro?
Old 04-03-2008, 06:42 PM
900hpSS's Avatar
Yes it could. The blocker ring is the brass part of the syncro that actualy locks in with the speed gear (5th gear). The syncro has multiple parts so that is what I meant, sorry if I wasn't specific.
Old 04-04-2008, 12:23 PM
900hpSS's Avatar
You know you could also have a messed up shift fork or linkage. How did it start? All at once or over time?
Old 04-04-2008, 01:11 PM
blu98ta's Avatar
I got the tranny from a board member who claimed all the gears worked fine, but I have never been able to get it into 5th since I installed the tranny
Old 04-04-2008, 11:44 PM
900hpSS's Avatar
it's hard to say then, but probly the syncros or the forks and linkage
Old 04-05-2008, 03:02 AM
jmd
jmd's Avatar
since 6th works, it's probably the teeth on 5th & on the synchro slider. Not bad to do, but while it's apart.....
Old 04-05-2008, 02:04 PM
blu98ta's Avatar
while it's apart what? It has already been built up, I just don't know the extent of the build up. I am only trying to fix whats wrong. Don't have the cash to to a whole rebuild
Old 04-05-2008, 03:35 PM
1gen3's Avatar
and you believe its already been built up after being told that all gears work fine by the seller?
Old 04-05-2008, 10:48 PM
calhoon's Avatar
Try to look through all the crap one gets on the internet!!!! This guy is clueless!!!.RIGHT its not specific. Its not even in the ball bark!!!!
First off it is NOT the brass part that locks the speed gear. It is actually the sleeve of the synchronizer. The synchronizer blocker ring for this gear is actually a friction-lined powdered metal part- NOT brass.Your problem is most likely rooted in the shift fork(bent) or the damage from repeated clash shifts.Even damaged shift fork pads can give your concerns. Only a teardown will find that out.
Old 04-06-2008, 07:34 AM
camaroguy26's Avatar
not sure but mine won't go into 5th if I downshift from 6th. I always have to go up to it. Even if I never release the clutch but go into fourth then 5th. I have a rebuild kit but i won't have the time to tear it apart for a while
Old 04-06-2008, 07:29 PM
900hpSS's Avatar
Right the sleeve slides over the blocker ring and the speed gear to engage everything, however there are blocker rings made of brass and yes others have clutch material on them. The blocker ring uses a cone clutch to "synchronize" with the speed gear. That is what I meant when I said it locks the speed gear and synchronizer. Sorry If you were confused but I do know what I'm talking about.
